i need Help plz
Are you sanding down the paint and making sure the the ring terminal is solid on there? Did you solder the ring onto the wire? You could also solder the ring onto the chassis.
Who the **** solders ring terminals to the chassis?
On another note, im suprised noone has said to remove the amp from the floor, perhaps the amp chassis is touching ground and causing a problem.
Idk man! But if the ground connection there is the issue soldering it on there will make sure it's on there.
I was under the impression that the amp was mounted to the box.. I guess I confused that when I read that he was taping on the box //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so should i like record a vid of what its doing ?
Would be a GREAT idea
it was mounted to the box put not anymore and i will take a vid 2morrow and upload it to the site if i can
Do eet. Be sure to show where your amp is, your connections on the amp and your new ground connection. Also if its still working that when you ground yourself from the amp to the chassis then show that in the video
i could not show u when use my self as a ground i can turn the gain up i only have 2 hands lol i will have to ask someone to recored it while i do that
Orion250R
Orion250R
iowa
Orion250R
Mike Mccabe
