I need help hitting low note with jl audio w6v2 12
underdogg
sc
my bos size is 15 height 20 length 40 width port size is 7'' from inside box out 15'' length 4'' width inside THE port
ON SOME SONGS IT HIT HARD BUT THEM LOW NOTES IS WHAT IM LOOKING FOR AN THEY WANT HIT THEM IS MY BOX BUILT WRONG .. BLOW THROUGH PORTED THROUGH MY CAB
It is hard to follow your post there. So far this is what I got out of it.
You want more lowerend bass.
Your enclosure is
15 high
40 wide
20 deep
Your port I'm not sure on. Perhaps pictures would help better understand? It sounds like your saying it is 15 x 4 and around 13" long. However if the enclosure is 15 high how is your port that high?
can i email u pic of the box an port opening so u can get a better idea an if i need to cut the whole back cab out i will to get that low note.. i cant post them pic pic size to large .. maybe u can post them or just look at them an help me out
what can u build or what do u reccomend for me
Assuming that is all correct your tuned in the mid 40s. Is it just a basic slot port design? Odds are you need to rebuild the enclosure based on your application and needs.
sending pic to ur email
that could be one problem i also have the 13.5s though so maybe around 34hz should whats your port length?.....could also be a number of things like amp settings stereo settings wire gauge etc.
i was wanting to sell these subs an go with 2 w7 12 because i though the w6 want hit that low note i dont know my amp setting but it was setup by a shop here.
i know jl spec are sealed volume 1.2 cubic foot
ported volum 2.0 cubic foot
port opening 40 square inches port length 9.75 inchesi dont know whats that tune to but thats what they reccomend for 2 w6 12v2
underdogg
underdogg
sc
TheUnderFighter
