I need help choosing some subs
el_miguelio
i dont know what subs to get plz help
(2) Pioneer TS-W3001D2
Features:
Woofer Cone Material: Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround: Wide-Roll, 3-Layer Fiber Woven Ar amid Radial with Honeycomb Cloth
Voice Coil: Dual 4-Layer, Long Voice Coil
Voice Coil Wire: Copper
Voice Coil Bobbin: Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction: Double Stacked (110oz)
Basket Design: Aluminum Die-Cast Rigid Chassis
Gasket: 1-Piece Rubber
Wire Terminals: Integrated Single-Sided Silver Compression Terminals
Specifications:
Watts MAX. Music Power: 3000 Watts
Watts Nominal Power Handling: 1000 Watts
Frequency Response: 18 Hz to 700 Hz
Sensitivity: 89 dB
Ohm Rating: 2 ohm or 4 ohm
Recommended Enclosure: 0.50 ~ 1.0 Cubic Feet
(2) 15" Solo-Baric L7 Series Subwoofer
Max Power Handling: 2000 Watts
RMS Power Handling: 1000 Watts
High-temp Dual 2 Ohms voice coil (428 Fahrenheit)
Frequency response: 18-100 Hz
Sensitivity: 89.4 dB
Titanium deposit impregnated cone woofer with rolled outer edge
Santoprene rubber surround
Full coverage back bracing
Poly-cotton semi-progressive spider
Spiralead tinsel-lead technology
Highly-efficient UniPlate pole-piece/back plate
Heat-reducing T-cut top plate
Solid pole piece
Cast-aluminum basket
Spring loaded terminals
Solokon 1 piece cone
SoloKon for strength and accuracy
T cut top plate for high magnetic field strength
Aluminum coil former (same as SoloX)
Pole venting at cone brace
Stitched and glued tinsel leads enable high excursion
Ribbed Santoprene surround
One Piece Ultra Rigid Molded SoloKon with 360 Degrees Back Bracing
(1)18" Dual 4 Ohm Solo X Series Competition Subwoofer
Power Handling:
Peak: 10000 watts
RMS: 5000 watts
Impedance: Dual 4 ohm
SoloKon injection molded polypropylene with spoke design cone woofer
Stitched rubber surround
Massive motor assembly
UniPlate V.2™ hyper-extended, pole/backplate assembly stays cooler with X-Vent™ technology (pat.pend.), yielding enhanced heat transfer for maximum power handling
S4 Quad Spider Array with perimeter cooling for improved air circulation
ARCTIC (Aluminum Rapid Cooling Thermal Induction Centering) Cap™ allows for even greater heat dissipation
Removable spring-loaded binding posts
3.5" Copper-clad-aluminum, edge-wound dual 4 ohms voice coil
Enormous magnet structure (approximately 100 pounds)
Sensitivity: 90 dB
(1)JBL W12GTi-MkII 12" DVC
12" Dual 6 Ohm GTI Competition Level Subwoofer
Power Handling:
Peak: 4000 watts
RMS: 700 watts
Impedance: Dual 6 ohm
Kevlar paper cone woofer
Nitrile-butylene surround
Differential Drive® Design motor
Symmetrical field geometry ensure linear cone travel and low distortion
3" Voice coil
Frequency response: 18-1000 Hz
Sensitivity: 91 dB
(2) Memphis 15-MC124 12"
RMS Power Handling: 200 watts
Peak Power Handling: 400 watts
Double roll polyprene surround: Better control over cone movement
Ribbed polypropylene graphite cone
Dual flat spiders with graduated rolls
Single 4-ohm voice coil
4-layer winding on 2" Kapton® former
Vented basket and vented spider spacer
Aluminum heatsink
Sensitivity: 88 dB
Magnet Size: 50 oz.
Mounting Depth: 5.5"
I GOT THE 2 MEMPHIS AND THE 2 PIONEER SHOULD I SATY WITH ONE OF THEM OR SHOULD I BUY ONE OF THE OTHER ONES i want to be heard from blocks away but i need to know wat subs are better and louder
You have a lot of research you need to do before you want to be heard from blocks away. I am 90% sure none of those subs you listed up there will do that, except for the solo x but i know you can't power it. Do some research on here and other places before blowing money on crappy equipment.
i have a Soundstream VIR-8310NRBT for my dash
i have a 1998 ***** am convertible
i need the subs and the amp
i want to sepend 400 on the amp
and like 500 on the subs
You don't have room for the Solo X (or what it takes to run 4k daily), try the L7s if you can spend 400 on an amp you should be able to power them decently and build a good enclosure.
The Memphis 12s hit hard in the right box with the right amp. I have 2 of the prs and people say they hear me coming a pretty good distance away and Im using a exonic 3000dx @ 4 ohms turned to about the third or fourth notch and it pounds like crazy. My friend has two of the pioneers and mine are much louder. The solo x is loud but cmon its a bit impractical unless your going straight comp.
you have done alot of research but you should also look at subs that are not in your area and a good one to look at would be audioque, incriminator audio and maybe even vibe audio or orion, with your car being a converable you should look at subs that take a small amount of space, the power doesnt really matter much as long as you have the right encloser
el_miguelio
el_miguelio
Laredo,TX
09civic
BP1Fanatic
BP1Fanatic
