I need help asap
ok koo thanks bro I feel like a pain in the *** but I was jus confused!
The sub is a dual 2 ohm. Meaning you can wire it to either 1 ohm or 4 ohm. NOT 2! Look up subwoofer wiring diagram. If the sub was a dual 4 ohm then you could run it at 2 ohm. Getting this? You're amp is not 1 ohm stable and that's the way you have it wired and the amp is going into protect. Wire it to 4 and you'll be pulling less watts but the amp won't go into protect anymore. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
roko
roko
YUMA, AZ
Josef344
BP1Fanatic
BP1Fanatic
