I have:
Kenwood Excelon x998 head unit
Polk Audio db651s speakers (4)
Alpine MRV-F300
I heard that head units start clipping at about 3/4 volume, that would be 26.25 (we'll say 26) for me. I want to know if I set my radio to volume 26 and turn the gain up (with all filters off) until something doesn't sound right, then back it down, is the gain set right?
I also heard that you should leave headroom. Example: If you turn your radio volume all the way up and then set the gains, you have to turn the radio all the way up to get it loud. If that is the case, why should I set my radio volume to 26 if thats the max volume before it starts clipping? There wouldn't be any headroom. The speakers sound fine with the amp gain at the line to the left of nominal and the HP filter on, but when I turn the filter off and play a bass heavy song it distorts (I forget at what volume, but not all the way up) So should I just turn the filters off and turn the radio volume to 26, set the gains, then turn the filter on and then turn the radio up as much as I want, even all the way? (it sounds good then, good volume at the lower, lowest, and the highest volumes, and doesn't distort)
I dont have any way of getting an oscilloscope.
I plan on turning the HP filter on at around 12 O' clock on the amp, I think it was around 80hz.
Alpine MRV-F300
