i need box plans made for my 9510
its a g. so i should deff. tune to 40hz?
i figured that would give me the best output with how DD stuff is made. i have my 10" BL tuned to 32hz, and it sounds amazing, so I had to ask.
Try it in the BL box if your not using it....It won't hurt...try to listen for any bottoming....though....You may have to trim the hole about a jigsaw blade around for the G basket to fit
cool. thanks. i was also wandering what would be the safest daily rms to run to on 10" 9500g?
right now I am going to be running it with my lanzar opti2000D at 1ohm. I think its CEA rated to put out 1700watts at 1ohm. I plan on doing all DD throughout (that is once DD puts out their '08 comp and coax)and i need to either get the M1a or M3. I was planning on the M3 but i need to know if it will destroy the sub or if i should just get another driver. or if the m1a will push the single 10" fully.
bobtista
bobtista
Nashville, TN
bobtista
