i need an amp
Okay first off you need a 1 channel (mono) amp. 2 channels are best used for mids and highs(if used at all). Now then, we need some information on the subs. What brand and model? What RMS handling? What voice coil? What is your price range for the amp?
2ch amps are fine for substage duty if the output @ whatever resistance load that it provides is appropriate for your needs.
But what subs you are using and the voice coil configuration of each is a worthy question...
No, no he doesn't.
His best choice, with the widest selection would be a channel amplifier bridged.
nG
You can get a Rockford Fosgate P5002, it will do about ~600 WRMS into a 4 ohm load. They're decently priced. I have one, and I've abused it for a while, and I still use it all the time, and still abuse it every once in a while. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The Van Man
The Van Man
ontario, Canada
95BlackGA
michigan born
    May 14, 2026
michigan born
    May 14, 2026
