i need amp
What kind of subs? How much you wanna spend? Hey i am from kirksville mo up north i been to lees summit nice to see MU natives.
i have two 12in rockford comp subs that take up to 1000w each but need an amp to power them i am willing to send up to about 300 for a decent amp if u find one or hve one please write back
I am thinkin they are the HX2s so I would get like a jbl1200.1 amp hould push them pretty hard and sound awsome just wire it in parellel into 2 ohms and it should be fine can get it for like 235 on ebay.
will this amp work well?
I found it real cheap at ugonet.com
Pyramid 700 Watt 2 Channel Amplifier w/Plexi Top Panel
Dual 10-LED Power Meters
2 X 350 Watts Total Output
Variable 0-+18dB Bass Boost
Adjustable High Low Electronic X-Over Network
Variable Gain Controls
Remote Turn On/Off
MOSFET PWN Power Supply
Soft Turn-On Circuit
Protection Circuiry
High And Low Level Inputs
High Level Molex Inputs
Gold Plated RCA Input Jacks
Power ON LED Indicator
LED Protection Indicator
2 Ohm Stereo Stable/Bridgeable into 4 Ohms
or another one from the same company...
Pyramid 1400 watt 4 channel amp w/ plexi top
Fan Cooling System
4 X 350 Watts Total Output
Dual Variable Bass Boost
Dual Fully Adjustable High Low Electronic Crossover Networks
Dual Variable Gain Controls
Remote Turn On/Off
Protection Circuiry
Dimensions (WxHxL)11.4"x2.5"x17
if I got the 1400w, would i be able to bridge it to make it a 700x2?
would u please go to ugonet.com to help me find the best one w/ the best deal?
thank u very much for helping me sorry i have so many questions;) :p
dont get pyramid they arent too good, rockwood subs are prolly way overrated to u should get something small i recommend the jbl 600.1 amp- those subs prolly have a low rms rating and u can get about 300w from the jbl 600.1
948
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
jared
jared
Lee's Summit, MO
blackgeltabs
