i need a video converter.
Guys,give you a Tutorial about Xlinksoft!Find it on a site!Hope to help you!
Xlinksoft video converter platinum 2009 Perfect tutorial(for iphone)
You may know Xlinksoft software. This video converter holds powerful functions and various features; quite easy to use. Now I take the function of video to iphone for example. New tutorials will be uploaded continuously for you.
iPhone Video (MP4) - is a new container format, a container format allows you to combine different multimedia streams into one single file. Multimedia containers are for example the well known AVI, MPEG , Matroska, OGM. MP4 is the global file extension for the official container format defined in the MPEG-4 standard. MP4 is streamable and supports all kinds of multimedia content, multiple audio-, video-, subtitlestreams, pictures, variable-framerates, -bitrates, -samplerates...) and advanced content like 2D and 3D animated graphics, user interactivity, DVD-like menus.
Google “Xlinksoft video converter platinum 2009” and install it to your computer.
1. There will be a hint pane after opening the install program, you can select one language from the seven choices.
Then is install interface.
3. Click “Add”, put videos to the converter, you can also directly drag the files to the interface.
4. Click “Output Format”, a menu of formats will be popped, then select iphone H.264 (*.MP4) format.
5.Click “Edit” to customize your setting.
Trim: support clipping any video segment t o convert.
Crop: adjust the video screen as you like
Padding:some videos have irregular aspect ratio, so in order to present the whole videos perfectly on your portable devices; you can use black color to fill in the margin (automatically by the converter or operate by yourself) or stretch aspect ratio of video pane.
Volume:adjust the volume; sometimes you adjust the computer volume to maximum, but it’s still hard to hear the sound clearly.
After finishing setting, click “Start”, then the conversion will be done within few seconds.
You can click “Browse” to set output path. Click “Open” then you can see all the converted files.
OK, conversion is done; you can put them into your iphone.
Tutorials are created continuously, hope they are helpful. More information: http://www.xlinksoft.com
hsdvza000
hsdvza000
Los Angeles
joshlon
vegang
vegang
