I need a very simple cut sheet.
Cut Sheet or a design?
thank you guys both for a reply.
i have the kove specs but was thinking it may be best to stear away from that.
it's going in my girlfriends car so i want it to sound good, but allso bump a good amount when i hop in to drive.
if you could do both for me that would be great. I plan on doing a areo port. so when you do design the box, design it for an areo port. instead of a slot port.
thanks guys.
seth.
1.75 cubes with a 4 inch aero at 12 inches deep tunes the box to 36 hz
12 wide or hi
14 wide or hi = box will be 1.9? to compensate for port and woofer displacement
20 wide or depth
cut sheet would be
top & bottom 15.5 x 21.5
sides 12x20
baffle and back 12x14
i always make all my boxes inside the top and bottom
and with the sides on the outside of the back and baffle but still inside the top and bottom
12 wide or hi
20 wide or depth
cut sheet would be
sides 12x20
cool. thanks man.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
