i need a new battery
  • 6
will a super start extreme agm battery from oreilly auto parts be fine with what i'm running or will i need to add to it website doesn't show ah rating
( ap1800d and powerbass asa 400.4x ) running sub amp at 2 ohms
will a super start extreme agm battery from oreilly auto parts be fine with what i'm running or will i need to add to it website doesn't show ah rating ( ap1800d and powerbass asa 400.4x ) running sub amp at 2 ohms
Do you have the Big3 done?What size /amp is the Alternator?..Im running 2 of those batts, with big three and 255 amp alt,..14.6v..lowest note on 14.4v..Im running a AB 4480.1D VFL Hybrid Mini,@1ohm at 2250rms,an Autotek 7204 BTS@4ohms, and Autotek Mean Machine 99@2ohms,and no issues..Great Batts Of my experiencing thus far, and one h3ll of a Warranty..3yr free replacement, and 4yrs after pro rated
i did the big 2 alt to batt is already 1/0 guage. did batt ground and alt to chassis ground with 1/0 gauge. atl is 180 amp took off of ram motor original was 160. but computer controls amperage so doesn't really matter if it was a h/o alt. so i should be good with just the one battery? it will be used as my starting battery also.
With what you say you are running,and ohm loads, I think you will be just fine man,myself..Neither amp is 90% effecient, and Im sure you wont tilt them at the Max gains..lol..If you need a bit more, add another batt i recommend
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
491
376
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
413
kirby mane
kirby mane
Tuscaloosa,Al
kirby mane
maylar
    Jun 2, 2024
    Jun 1, 2024
