I need a budget 1000 watt 1 ohm stable mono amp
That PPI 1000.1d is a pretty solid little amp for the money..I have one in a work truck pushing an xfl 12@32 htz in 2.0 cu ft slamming just fine,and a 600.2 on the front stage doing fine.Not a bad little amp
Thanks, just ordered it. have you ever had it overheat? I live in phoenix and the trunks of cars her can easily push 160 degrees in the summer.
I placed 4 washers under each mounting tab to get some air underneath(I also have a Stinger scroll fan in place where it has taken the place of my mmats amp at the moment)..I recently put it in, so we will see when it gets hotter, but The scroll fan should keep it quite cool and being raised as I do all my amps.Fans are cheap.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
457
359
Fat...Lac
Fat...Lac
Phoenix
tymoto21
    May 31, 2024
    May 24, 2024
