I know the BEST sub!!!
Originally posted by Phatillusion Zane, you are impressed with the xmax for the adire audio. Let me point out that the Bazooka EL1204 xmax is 28.956 (if my source is correct). I have a pair of these in my car and they do hit very hard given the fact that they are only 200 wRms, and I am only running approx. half that. But they are not nearly one of the top speakers. So how can you say that the adire is very good based on the xmax?
I am not merely basing this on XMAX alone, allthough the Motor/VC assembly is quite impressive with its excursion ratings- however, notice that Adire rates thier XMAX one way- that means that Peak to Peak excursion would be greater.
Here's What I dug up for you for The Adire Audio Shiva (12") and the Bazooka EL1204 (12")
Bazooka EL1204
Min. Enclosure Volume .6 cu
Recommended Enclosure 1.0 cu
Max Vented Enclosure 2.0 cu
Revc (DC VC Res) 3.4 Ohm
Fo (Res Freq) 30.4576 Hz
Zo (Zmax at Fo) 46.3834 Ohm
Sd (Piston Area) .0501 sqM
BL (Flux*Length) 13.7740 TM
no (Ref Effncy) 0.6075%
SPL0 (Spl at 1W) 89.8538 dB
Xmax 29.1MM
Qms 4.9861
Qes 0.3944
Qts 0.3655
Vas 87.6974 Litr
LE 1.4 Mh
Cms 237.4368 uM/N
Mms 115.0008 Gram
Mmd 108.3783 Gram
Power Handling 50-200 watts
MSRP $179.95
Adire Audio Shiva
Re 2.9 ohms
Le 2.12 mH
Qms 6.5
Mms 125 grams
Qes 0.41
Cms 0.47 mm/N
Qts 0.39
Rms 2.54 N*s/m
Fs 21 Hz
Sd 481 cm^2
Vas 151 liters
BL 10.80
Xmax 15.8 mm one way 31.6 peak to peak
EBP 51.2
SPL 87.2 dB @ 1W/1m No 0.37%
Pmax 375W per voice coil; 650W total to the driver Distortion
Quantity Price Each
1 to 3 $125.00
4 to 9 $115.80
10 to 25 $107.34
26 and up Contact factory
Would you say that they would outperform the MTX 8124 both Sq and Spl?
Yes.
And As Tom Nousaine puts it:
"Raw Drivers (for the project-minded): 12-inch woofer: best mix of price and performance for subwoofer projects. These guys have long, clean stroke: ...Shiva..."
- The $ensible Sound, Sept '99, (716) 833-0930
Also, if you are familiar with a man by the name of Siegfried Linkwitz, (think- Linkwitz-Riley Crossovers) - check out what he had to say here:
http://www.linkwitzlab.com/woofer2.htm
No offense to anyone, I'm only trying to get my brother a good system, and if I can save him some $$, then that's tight, but I don't want to tell him to get something and not have it to perform as good as what he has in mind. He pretty much paid for my system which cost a total of $600, including everything from the HU to the wiring, I do my own installations, so I told him I would build him a sweet system. He really wants the MTX 8124, but if you can tell me that the adivas can outperform the 8124, then that sounds like a better deal to me.
Thanks
The best thing you could do is check the shiva's out a little further here:
http://www.adireaudio.com/cd/shiva.htm
If in any further doubt, you may also wish to contact Adire Audio's CEO and Founder Dan Wiggins at dwiggins@adireaudio.com
Mr. Wiggins is a very freindly and knowledgeable person. He typically goes out of his way to explain things in detail to make sure that they are easy to understand for everyone. Believe it or not, he does talk to the everyday average joe quite a bit too. Mr. Wiggins sets a fine example for his company and is very professional and polite. Definately- a very interesting guy to talk with....
This should give you a place to start.
take it easy,
-zane
ArcaneParadise
ArcaneParadise
California
Phatillusion
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
