I just blew my brand new head unit (Blaupunkt Toronto 420BT)!
Should I be confident the replacement will be reliable?
  • Yes, Blaupunkt is a good brand, you just got a defective one, the replacement will be great
    Votes: 3 42.9%
  • No, Blaupunkt is known for constantly blowing up, choose a more reliable brand, like . . .
    Votes: 4 57.1%
  • User error, stop abusing your head units and they'll treat you well
    Votes: 0 0.0%
  • Total voters
motochrome
16
Midwest
I haven't had a "system" in over twenty years, and was REALLY enjoying finally having this for the three days it lasted. I'm bummed. I pulled up to a stop-light and it just quit. I didn't smell anything that resembles "electrical smoke", but the display went dark and it wouldn't turn on again. I did have the volume about 93% of the way up . . .
I thought I blew a fuse, but checked all three (including the one in the Head Unit itself) and they're all good. I even checked them with a continuity meter just in case. Then I went a step further and made sure voltages were getting to the harness where it plugs into the back of the HU. All good. Constant, keyed and I even double-checked the ground and they're all golden to the point where the harness plugs into the HU, so it's not the wiring (which is all soldered and heat-shrinked into a factory harness connector/adapter).
My question is regarding the probability that I got a lemon, or if I abused it by cranking the volume? I just want to make sure this doesn't happen again when the replacement comes. I've never blown anything before in my life, and I always make sure I keep the levels below any audible distortion, so as not to clip the outputs. I had it loud, but it was still sounding clean.
When I removed the HU, I smelled it real hard, but nothing smells burnt at all, so it's weird. I would think that if I blew its internal amplifier, I'd smell "electrical smoke" and it might still turn on, just wouldn't output any signal . . . but this thing is as dead as it gets.
So should I take a chance on another one? Is Blaupunkt an unreliable brand? Is it likely I just got a defective unit, or did I cause its death somehow?
I just ran all the wires cleanly hidden, including the external microphone for the bluetooth calling. I don't want to go through soldering another 18 wires or so for a different head unit, if I don't have to.
it's possible you got a bad product, this why they make warranties. with that being said i have no idea what headunit you're using or who the company is, but i would call them and explain your situation and ask about getting it warrantied. i'd be pretty upset if i bought a new headunit and it failed so quickly, running it at near max volume can't damage a headunit lol your speakers would be blown before that happened unless you had a direct short or something
i have no idea what headunit you're using or who the company is [snip] a direct short or something
"(Blaupunkt Toronto 420BT)!"
The replacement is already on its way, so I won't have to re-wire any harnesses. If the replacement does the same thing, I'll look into Alpine HU's or similar.
You're right, I guess if the speaker wires shorted or something, it could've blown the HU . . . I guess I'll double-check all the speaker wires to make sure none of the positives have continuity with any of the negatives. Good call. (All I did was plug in the factory-adapter leads they sent me, but I'll check it out anyway - The new JBL speaker's Voice-coil could have shorted out internally and blew the HU's amp . . . unlikely, but it's possible.)
My intention in saying that was to tell you I've never heard of that brand before, and can't say what type of quality you're getting.
Blaupunkt makes ok product. I've had a couple of their HUs when I've wanted to maintain a stock look. Does the HU have a reset button perchance? It may be worth a shot. Also as Trumpet said testing it on another power source wouldn't hurt. Defective units do happen on occasion though.
Trying a different power source without disassembling my soldered/heat-shrunk harness could be done by smashing some leads into the chassis of the radio, driven by my 12V power supply. I'll try that, but I did verify proper voltages at their terminations in the truck. I'll go ahead and give it a shot though . . . Luckily my multi-meter leads fit into the banana plug outlets of my 13.8V DC (12V) power supply, and I was able to grab onto the little tangs inside the radio's chassis with alligator clips, but it didn't do any good. I matched up the tangs with the wires on the connectors for the appropriate positive and negative connections, as well as the 12V with key on. Dead as can be. Nothing.
I could not find any reset button on the unit, or in its manual.
I guess this little experience cost me a CD that I can't get out of the defective unit, and a few days I'll have to wait without any audio in my truck - makes driving lame, especially after being teased for a few days of pure sonic bliss.
They're o/s...esp that hu.
Old School? Sorry, I'm not aware of that abbreviation/terminology. I tried google, but only came up with: Operating System, Outside, One Size, on sale, Offset, Overseas, Outstanding (unpaid insurance claim), Out of State, Oversize (Canada Post), On Scene, Outstanding Shares (stock market), Operational/Support, Outstation, Ocean Surveillance, Outlaw Shark, and Organisation/Schmelt (Germany/Poland). Are any of those what you meant? Maybe you could offer a hint?
Out of Stock? Overrated S...? Am I close?
Blaupunkt was a mid-lowerish line, a little above Jensen and JVC, used to sell them at Best Buy back in the late 90's, so old-school //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Can't speak for todays quality though...
I highly recommend the Pioneer DEH-80PRS!!!
It has 5v pre-outs, has a very clean signal, full volume (62), eq set to B. Boost, no clipping (tested with o-scope).
They used to be decent. Preferred them over lower end common brands. No idea about today. I still have 3.5" blaupunkts in my car. Back in '96 they were some of the only 3.5s sold around here but I didn't have internet then. Haha.
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
682
Thanks for all the help guys I'm going to buy a new sub, looking at some of the suggestions u guys gave. I have a small sealed box now but will...
41
4K
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
870
  • Locked
I have a few of these head units. Brand new, unopened and ready to ship out. $925 PayPal. Shipping included to conus.
motochrome
motochrome
Midwest
motochrome
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
