I finally found it!!!
why not get a 1ohm stable amp?
hifonics bx1000d or even the bx1500d if they can handle it
This is the most Practical way I think. The Hifonics BX1000D will pull less current than that class a/b Profile amplifier. Plus the Hifonics will give you some headroom at 1000 watts at 1 ohm which is 500 watts split between your woofers.
Whats the rms rating on the subs? If its 4-500 watts then yes you can get the hifonics. Run each sub in parallel for 2 ohms on each sub and then run the subs in parallel to the amp to get 1000 watts and 500 watts a sub.
To get a 1 ohm final load. Take each + terminal on each subwoofer and wire them together, do this for the negative terminal as well. This will make each subwoofer a single 2 ohm voice coil. Take the + of both subs and wire them together and do this for the negatives as well. This will give you a 1 ohm final load which will give you 500 watts rms a subwoofer from the Hifonics BX1000D, and as far as I know you cant find it anywhere as cheap as ebay, thats where I purchased mine from.
Wondering where you got this information?
its because the profile-ma-whatsit is class A\B, you can clearly tell by the size of it.
the hifonix amps are mono class D amps. they are more efficient (hence the 1-ohm load) run cooler, and draw less current. this is why class d is such a sought after sub-amp. //content.invisioncic.com/y282845/emoticons/cop.gif.57eb2cc10a7efd04d31083ca3c30d53c.gif
but i would rather go with the mono 1-ohm load
courtisy of rockford fosgate
but thats just my 2cents.
sudrummerboy
sudrummerboy
Atlanta, Ga
req
