i did a search and im confused.
janix
like the title im confused.
i have a batcap 400 and a dei d2400 amp, im using 0ga from battery to batcap and 4ga from batcap to amp..
ok what type and size of fuse/circuitbreaker should i use off the battery??
and i read somewhere on http://www.bcae1.com i think thats it.. that you shouldnt use a inline fuse holder because its enclosed on both end.
so i was just wondering if its okay to use the inline fuse holder and if it is what type and size fuse i should i buy, because i already ordered an inline fuse holder from knukonceptz.. and if i shouldnt use that inline fuse holder which type of fusebreaker should i get. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
and if your wondering, im running a 150amp circuit breaker off the batcap. i read on http://www.bcae1.com, that circuit breakers are bad.. so should i change it to a fusebreaker too??
300A fuse. You fuse to protect the wire. Since the current carrying capacity of 1/0 wire is 350A, use a fuse slightly less. You will only beable to find ANL fuses in that size, and get the fuseholder & fuse from knu... I did, and its nice. Circuit breakers are bad (if they are exposed to the elements). The contacts can corrode and then the breaker is not operating like it should.
janix
janix
janix
