HU DSP/EQ/X-over or Audio contorl EQX?
mestapho
I'm about to install my first system since 'Nam.  I have a Pioneer MVH-S600BS installed.
I have my old, circa 1993 Audio Control EQx series ii that is in perfect shape.  Which should I use for EQ/X-over duties?
System will be Pioneer GMD8604 and GMD9601.  Sub - 4 8" Blaupunkts,  Mid is TBD but some 6.5 maybe silver flute, and Vifa ebay tweeters.
I'm pretty sure the Pioneer is the better choice as it is 25 yrs more modern but thought I'd ask anyways.  It appears the current EQx is identical.
The other thing is the amp doesn't have a SS filter so with the HU X-over I'm pretty sure I can set HPF and LPF for the sub channel.
oldschool stuff like that is cool, but really more for nostalgia and collection purposes. it doesn't hold a candle to the **** we can do with new hu's and DSP's. you can probably sell it for a good price
I’m still running an EQX and I’ll tell you that thing sounds great with the HU handling time alignment. I have a JL TwK DSP in each of my other two vehicles and although you can’t beat the DSP with a proper tune, there is just something about that EQX that just sounds good. I’m nostalgic, so I say keep it.
I would say keep it as well.  I have heard some of the older Audio Control products have had noise issues but other than that they sound awesome.
No noise issues with my AudioControl stuff and that is with a DQ61, EQX, and two 2XS crossovers. Anyone who has any noise issues with these likely did the install wrong. All of these devices can send over 7 volts to your amplifiers; keeping the noise floor of the amplifier to the lowest it can be. Although old school analog, these things are top notch quality. They would also make great active crossovers for home audio gear with a cheap plug in 12 volt power supply.
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
You will get a boatload of opinions on various types. I will say this. Since the new release of the AudioControl firmware/interface compared to...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
708
470
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
439
mestapho
mestapho
Sac area ish, CA
Jcsaudio
SlugButter
    May 4, 2024
slater
    May 2, 2024
