hpf and setup
  • 2
Are you using a subwoofer? Usually, the LPF filters the signal going to the subwoofer output, and the HPF affects the front and rear speakers. If you're using crossovers on your amplifier(s) then you should turn the head unit filters off.
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
620
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
943
italianlifter17
italianlifter17
ohio
KaeZoo
    May 22, 2024
    May 22, 2024
