S s_b_801 Junior Member 7 0 UT Nov 13, 2006 #1 I adjusted one of the sample boxes to fit my application, what do you guys think? Any help would be appreciated. If this is not going to work, should I just go sealed? Click to read more...
S stuckinok 5,000+ posts Sick My Duck 5,457 0 Rio Rancho, NM Nov 16, 2006 #4 what sub is it for? Click to expand... x2 i didnt know boxs make sounds without subs
OP S s_b_801 Junior Member 7 0 UT Nov 16, 2006 Thread Starter #5 Arc Audio Kar10d Impedance : 2 or 8 ohm Resonant frequency : 28.8Hz Sensitivity : 86 db RMS power handling : 200 watts/ 400 peak Electrical "Q" : .889 Mechanical "Q" : 4.781 Total "Q" : .749 Equivalent volume: 57.26L One way linear: 8 mm Mounting depth : 5.5" Optimum sealed enclosure : 1 cuft Ported enclosure : 1 cuft
budahbuddy803 10+ year member CarAudio.com Veteran 4,970 11 Aiken, SC Nov 16, 2006 #6 that box should sound amazing!! mdf produces a great sound. haha speaks make the noise which im sure you knew?
Thieroff 10+ year member The Master of Meatcutters 2,768 0 Pittsburgh Pa Nov 16, 2006 #8 haha, i wouldnt port that sub if I were you Qts is way too high CT
Thieroff 10+ year member The Master of Meatcutters 2,768 0 Pittsburgh Pa Nov 16, 2006 #9 Seal it, put it in 1 cube, call it a day CT
OP S s_b_801 Junior Member 7 0 UT Nov 16, 2006 Thread Starter #10 Seal it, put it in 1 cube, call it a day CT Click to expand... Thats what I will do, Thanks for the reply! "boxes don't make sound" ha ha, should have seen that one coming! It was a pretty stupid reply though.
