No__ID
how would i wire 2 hifonics bx1000d's up to 3 treo ss12's (can i do this)? and what would the final ohms be? thanks
???ok first thing you need to do is find the specs on your subs and then you need to go to crutchfield and read there help pages and they will explain wiring for subs ( how to get the ohms you want) heres the tricky part about the wiring. you need to make sure that the hifonics have good grounds and have plenty of power to supply them now you run one speaker on each mono and then you can wire one sub between the two amps (never tried it with hifonics but it will work with most amps, ((((you need the amp input levels almost exactly the same and dont change this once you set it)))(((this is risky so try it at low volumes then slowly turn it up feel your amps for excess heat, make sure you have the proper fuses installed also))) this should not damage the amps unless there is something previously wrong with them
ok i have a directed 1100d 1000rms amp and a lightning audio 4 channel amp 300rms and i am putting this in my intrepid now what will i be needing so it wont drain my car because my lights keep deming when the bass hits and how should i install this
Look retard! I'm not the only one telling you to stop jacking people's threads! GO FVCKING MAKE YOUR OWN.Make your ownd theard dumb fvck!111
