how to wire toggle swtich
  • 5
3 prong will let you have 12v power in - A or R is for accessory/remote(middle prong) and then Ground. Power wire from your battery bank to 12v in, power wire from your volt meter to the accessory/remote(middle prong) and then ground that volt meter. Then ground wire from your toggle switch to a ground.
ok thanks im try this out
You want a switch to turn the meters on and off? You could just run the red wires to a switched ignition wire in your car, and the white wires to where you want to measure. Black to ground. No switch required.
If you want a rocker switch anyway, just put it between your switched ignition power and the red wires on the meters.
You can also use your amp remote wire to turn them on and off and hot goes to + battery term For one volt meter then other + amp for voltage to amp then ground them both to something or - battery
really? did you do the install also? lol Put the switch on the red wire before the volt meter... inline. like a fuse holder. wahbam
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
290
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
790
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
805
biglion
biglion
nahsvlle tn
DonH
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
