How to wire this up to get 2 ohm ASAP
Taken off this site from an older post.
"if you have two component sets for each channel, you simply wire the crossover inputs in parallel. the crossover outputs are normally connected to the woofer/tweeter. the amplifier will see both crossovers and thus both speakers in parallel, reducing the impedance load"
Pretty sure you will loose control over fade/balance control.
Bridge a 4ch amp, you can't magically wire 4ohm comps to 2ohm...
the reason im running 2 comps to one channel is because my amp is too powerful for my speakers so im running the speakers together. I know the ohm load drops and adds power but it will be less power fed to each speaker this way
Ok rocket scientist, why did you dislike the post above??? It was the proper reply and what you should be doing.
Run each side on it's own ch and turn the fuggin gain down....
southport2014
southport2014
Indianapolis, IN
mlstrass
