how to wire cap?
  • 2
EVOECLIPSE
i was just wondering how to wire up a cap. i am sure ya use a fuse like normal right? really that is my question? say you had 4 ga wire running from the bat. and you had a distrabution block that had two 8 ga wires running out. one amp is for componets (300 watts) and the other is for subs (800-1000). could you use it before the distrabution block or are you supposed to use it on the sub amp only? thanks
i have may set up after the distbution block going to may amp that is pushing the sub that is the correct way to install your cap.
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
514
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
890
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
867
EVOECLIPSE
EVOECLIPSE
New Paris, OH
jeffrich21
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
