How to wire 3 JL 12w3v2's?
What amp?
For a mono amp, your options are:
Subs in series (8 ohms per subs), parallel to amp: 2.6 ohm load
Subs in series (8 ohms per sub), series to amp: 24 ohm load
Subs in parallel (2 ohms per sub), parallel to amp: .6 ohm load
Subs in parallel (2 ohms per sub), series to amp: 6 ohm load
Go with the first setup I listed
You wire the subs in series for an 8 ohm load per sub, then wire them parallel to the amp for a 2.66 final ohm load. Remember:
Parallel wiring = impedance of coil / number of coils
Series wiring = impedance of coil X number of coils
So the for subs in series you get: 4 (ohms per coil) X 2 (# of coils) = 8
Then parallel to the amp you get: 8 (ohms per sub) / 3 (# of subs) = 2.66
Hope that helps
Originally posted by snova031 Subs don't "handle" the load, they create it. The amp is what has to be able to handle the ohm load.
ahh.... so true. I used my words incorrectly. Thanks. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
SirSteve
SirSteve
USA
SirSteve
