how to wire 2 tweeters to one crossover
If you wire them in parallel, you would double the crossover point, making a large gap between the mids and tweets.
If you wire them in series, you would cut the crossover point in half, and possibly ruin your tweets.
Pick your poison.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
try it out & see what happens then
Why would you want to run two sets of 28mm tweeters, with one set of 6 1/2mids??what is the rms rating on you amp??
are you looking for SQL.
SQL!!!! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
so i quess you want SPl ?
most of your vocals come from your mids, so by adding another set of tweeters wont make it much more louder.
where do you have your tweeters mounted @.
if your tweeters are mounted down low, maybe you can mount them higher on your door panels or even in your pillars.
So what are my other options? I already bought the tweets since I was told by dd I could run 2 pairs off each crossover.
Can I use a bass blocker and run the tweets off the rear channel of the deck. Maybe use as rear fill ?
What would you guys do? I don't wanna damage any of my gear.
You shouldn't bother adding the 2nd pair of tweeters.
Completely unnecessary and a PITA to make sound decent. Stupid idea.
And as mentioned; you wouldn't want to add them to the same crossover. Changing the xover point is no good.
burzendowski
burzendowski
CA.COM
squeak9798
    Jun 20, 2026
    Jun 20, 2026
