How to start on modifying door for 6x9's?
If you want bass then why not just add a 12" sub? A good set of 5 1/4" components plus a decent 12" sub would be pretty nice.
I helped a buddy to replace all four 6x8s in his 96 Explorer plus a new headunit, but there was still not enough bass to be worth talking about it.
I'm adding 2 12" alpine type r's with a discus soon. Are external crossovers fairly easy to set-up?
it's not worth putting anything more than 5.25's in the doors. unless you plan on putting something like 2 comp sets up front. then you'd be doing all new door panels anyways. get a good comp set. 6.5 will get you a tad more bass but not alot. 6x9 require way too much air than a door can supply. it's a bonniville? doesn't it have 6x9 in the back? goto an audio store and listen to 5.25, 6.5 and 6x9's and see for yourself. comps aren't just about mounting the tweets. but, just by mounting them in different areas in the car can make it more of a surround and filling sound.
Yes, it has 6x9's in the rear deck.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
Xanthous
Xanthous
St. Louis, Mo
Xanthous
    Jun 1, 2024
    May 31, 2024
