How to safely run 2000 watts RMS?
mcglnch5
I have a 95 Nissan Sentra with upgraded High Output 140 amp alternator. I have 2 Rockford fosgate amps 1 is bd 1000.1 and the other is 1001bd, so pretty much the same wattage, I'm running 2 12' Alpine type X's 1000 watts each so 2000 watts rms. My question is do I need to get a bigger alternator or more batteries? I have a Optima Yellow top battery under the hood, and a Kinetik HC1200 in the trunk, so is this enough to power both amps/ subs? Any help would be much appreciated!
Thank you,
mcglnch5
Do you have big 3 installed?
If so then you are pretty much safe as the alternator should be able to do 2000 watts + the batteries will save it from having to stress as you still have to add on a extra 200-400 watts for the vehicle stock usage.
Do you get any voltage drop or dimming lights?
I was just worried because I don't want to fry/ kill my alternator.Thank you for the replies.
You wont kill your alt atleast not for a while, But you do run the risk of killing your amps.
The more voltage drop you have the more resistance which means more heat causing both the amps and subs to heat up or possibly fry.
If you have little to no voltage drop you nothing to worry about just don't play at full volume all day everyday.
Mylows10 can get you a good deal on big 3 wire shrink wrapped and terminated. If you measure where you want your fuse on the + wire he can probably cut it and put it in the block for you. Otherwise you need to cut it and fuse it yourself. I got a set of 0 gauge OFC and was very happy with it.
As for the voltage gauge. I have a digital power distro is that good enough?
mcglnch5
mcglnch5
Pottsville, PA
LosIsATool
