How to properly setup time alignment
GlocksRock
Glock > You
I have a Rockford Fosgate DRS1 in my car and I"m looking to set the time alignment. Is there a reccomended way to do this, do I need to input measurements for all speakers, or just certain ones? I'm only running a front stage and it's ran active, so I can set delays for the tweeters in the dash, and the mids in the lower door area.
The DSP calculates the milliseconds based on the distance I input. But my question is should I input data for all speakers, or just certain ones?
Keep in mind that calc is only a general guideline it does not factor in hearing loss difference in either of your ears. After that id recommend turning sub and mids off then play a center vocal song with only the tweets, adjust values till its dead center, turn off tweets and turn on mids, the the exact same thing.
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
586
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
990
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
906
GlocksRock
Glock > You
GlocksRock
Charlotte, NC
Jeffdachef
    May 18, 2024
    May 18, 2024
