How to properly install???
sealw98
I'm in need of the proper soultion to hooking up my 3 amps in the trunk. I have 2 mono amps that run at 1250watts each and are fused at 120amps each and then I have my 4channel that is 250.4 and it is fused at 60amps. I'm being told to run 0 guage from the battery to a dis. block where it will split into 4guages for each of the amps is this correct and is there anything else I should be aware of?
0 awg with a 300 amp fuse near batt. See if you can get a fused disribution block. Be aware that your vehicles charging system will need to be upgraded.
sealw98
sealw98
detroit
indosia
