How to mod you amps?
What exactly are you wanting to "mod". There's different "levels" of modications.
The simplest is to simply swap the fuses for a larger size. Moderate is typically just cutting out the protection circuitry. More advanced is actually replacing key internal components with different parts.
sounds exciting:naughty: make me wanna mod amps now
it can become quite fun when you take certain high power amps, remove their protection circuit, and half *** put a big cap on the outside and watch it catch fire when people try burping .5ohm tones lol:naughty: . give you a cookie if you guess the amp i speak of.
just makin the output higher like lowering the ohm load etc. and i was just wonderin if there was like a how to ya know?
there is no generic how to mod your amp blueprint as most amps have different circuit boards. now if you tell us the amp you have, someone might be able to help you mod the amp you have.
PG?
mtx 1505d?
Mr. Nipples
Pimp ***
Mr. Nipples
Grand Rapids
bumpin_blazer
