I'm going to post up a video in an hour or so giving full detail of my system. Maybe someone can then explain why I'm dropping.My big question is did you do the big 3 or are you trying to pull that 320A off of a tiny 8 ga wire? That would explain a lot and what are your runs to the back are they 0 gauge and how good is your grounds. It is more than like not the alternator. I am running 2krms off of a 300amp alt and not seeing that kind of voltage drops but I also have 3 runs each of 0 gauge power/ground front to rear. Along with multiple 0 gauge grounds on engine and frame along with two 0 gauge runs from the alternator to the battery.
Heres the video of me giving the lay out of my system. ill make another video tomorrow showing how it drops with the bass actually on.more info on your setup....how is it all wired, grounds?
What is the voltage drop like with your rpm's up around 1500-2k
Some of those big alts don't do alot at idle (but with only 1600w it shouldn't drop that bad)
Anybody?
Am I the only one that cant stand to look at a video where 50% of the screen is a black bar on the left and right side?Heres te video of my giving the lay out of my system. ill make another video tomorrow showing how it drops with the bass actually on.
Alternator - YouTube
He said he wanted 14.8 volts so that it does not drop into the 13s. Even at idle a DC power alt should provide more than enough current for 1600 watts. Many stock alts can handle 1600 watts at idle or a little above.He has not shown any drop yet. You could potentially see tons of drop from that alternator at 800RPMs using the stock pulley.
