i have a Dc power alt. why do you need it to run at 14.8?That would change it? I thought you'd need a regulator of some sort no? DC said the alt runs like that because they made it that way. If I wanted it to run at 14.8 I'd need to send it back to them.. Which I definitely don't want to do. So I was looking for an alternative
You sure your battery isnt bad?What kind of battery/batteries you running?With that alt,and @1600 rms, you shouldnt be dropping that much,.You have the BIG 3 Done?So it doesn't drop into the 13s. I have a 320 amp alt with a 1600 watt system.
Ok... I run a crescendo bc3500, while im sitting at idle playing full tilt im only drop 13.6 or 13.7volt. And i have a 220a alt. You shouldnt drop anything with that big of altSo it doesn't drop into the 13s. I have a 320 amp alt with a 1600 watt system.
