How to install a deck in 99 maxima
ok. pull trim up and off around shifter. then 1 phillips screw holding the left side of the ash trey. after you removed that screw pull the ash trey out... it's a little tight but will come out. then pull on the vents above radio. those will come out to. then you have two phillips screws on the bottom and top of the radio assembly. remove those screws then remove radio assembly.
now you have to remove the old radio. and iso mount ur new one.
neek804
neek804
Richmond,Va
neek804
