How to hook up 2 amps, 5 channel?
  • 2
AySly
25
Modesto
So this is what I currently have:
Front Speakers & Back Speakers Alpine Type R sp57c 100Watt RMS 300 watt peak
Subwoofers: MTX Thunder 5500 10" 300Watt RMS
Amplifier #1 BOSS Riot R2504 180 RMS 1,000 watt peak 4 Channel
Amplifier #2 MTX Terminator Mono t250/1 200 Watt RMS 400 Watt peak
Pioneer Stereo Deh 150-mp
My question(s) is how do I go about setting this up wiring wise. What all would I need as my stereo only has 2 RCA outputs. Also any suggestions on what I should get rid up/perhaps upgrade/buy to make things more equal.
Well you have a 2 part question really.... To hook up your system as it exists now, I would use the hi-low adapters that are likely included with the Boss amp and use those to hook up the R2504, I would then use the RCA's (Set to subwoofer mode)to the T-250.
As for the second part of your question of what you should change upgrade too, well it's dependent on your budget. The only parts I think right now that I would recommend keeping are the Type-R speakers, and if your not looking for a ton of bass the Thunder 5500.
I would definitely ditch the boss amp... For a budget 4 channel you can pick up the Dual XPR84D at Walmart for $89 (Add the two year extended warranty for $9), You can grab a better HU with 3 pairs of RCA outputs for under $100, and you can get a more powerful sub amp for $99 (JBL GTX500 @ Crutchfield).
So the order of what should be improved in my opinion is:
1. 4 Ch. Amp
2. HU
3. Mono Amp
4. Subwoofer
5. Speakers
1. 4 Ch. Amp
2. HU
3. Mono Amp
4. Subwoofer
5. Speakers
I appreciate such a large and detailed response! I will definitely be selling my stereo, amp and speakers and purchasing a the ones you mentioned above or perhaps even better if I can find some used products.
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
AySly
AySly
Modesto
AySly
    May 12, 2024
Brendon Jenness
    May 11, 2024
