How to hook up 2 amps, 5 channel?
AySly
So this is what I currently have:
Front Speakers & Back Speakers Alpine Type R sp57c 100Watt RMS 300 watt peak
Subwoofers: MTX Thunder 5500 10" 300Watt RMS
Amplifier #1 BOSS Riot R2504 180 RMS 1,000 watt peak 4 Channel
Amplifier #2 MTX Terminator Mono t250/1 200 Watt RMS 400 Watt peak
Pioneer Stereo Deh 150-mp
My question(s) is how do I go about setting this up wiring wise. What all would I need as my stereo only has 2 RCA outputs. Also any suggestions on what I should get rid up/perhaps upgrade/buy to make things more equal.
Well you have a 2 part question really.... To hook up your system as it exists now, I would use the hi-low adapters that are likely included with the Boss amp and use those to hook up the R2504, I would then use the RCA's (Set to subwoofer mode)to the T-250.
As for the second part of your question of what you should change upgrade too, well it's dependent on your budget. The only parts I think right now that I would recommend keeping are the Type-R speakers, and if your not looking for a ton of bass the Thunder 5500.
I would definitely ditch the boss amp... For a budget 4 channel you can pick up the Dual XPR84D at Walmart for $89 (Add the two year extended warranty for $9), You can grab a better HU with 3 pairs of RCA outputs for under $100, and you can get a more powerful sub amp for $99 (JBL GTX500 @ Crutchfield).
So the order of what should be improved in my opinion is:
1. 4 Ch. Amp
2. HU
3. Mono Amp
4. Subwoofer
5. Speakers
1. 4 Ch. Amp
2. HU
3. Mono Amp
4. Subwoofer
5. Speakers
I appreciate such a large and detailed response! I will definitely be selling my stereo, amp and speakers and purchasing a the ones you mentioned above or perhaps even better if I can find some used products.
AySly
AySly
Modesto
AySly
