These guys are both wrong op. What you do is use the smallest wire you can find to ensure best connection and proper pressure resistance. Next you cross them several time to make a swirl pattern with the wire, this boosts power and db's. Next thing you do is fasten a capacitor inside the box to help with the dimming this setup is sure to cause, I advise 1 cap per sub atleast 8.75f each. Than you turn around 3 times, say blaca blaca bam and presto, its now 100% done.
I hope this was helpful
it wasn't funny the first timeThese guys are both wrong op. What you do is use the smallest wire you can find to ensure best connection and proper pressure resistance. Next you cross them several time to make a swirl pattern with the wire, this boosts power and db's. Next thing you do is fasten a capacitor inside the box to help with the dimming this setup is sure to cause, I advise 1 cap per sub atleast 8.75f each. Than you turn around 3 times, say blaca blaca bam and presto, its now 100% done.
It was an accident the second time and nothing was ment to be funny! I gave him solid install tips //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifit wasn't funny the first time
I usually don't give install tips, but I did install my tip in your mom.It was an accident the second time and nothing was ment to be funny! I gave him solid install tips //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifI usually don't give install tips, but I did install my tip in your mom.
