hardhitta47
- Thread Starter
- #16
My bass boost is kept at 0 or 1. I played with it a couple times and it only seemed to have an effect when the volume was turned down. As soon as I get my car back tonight, I'll mess with that sub-sonic filter on the amp and let you know.I would play a 30hz tone and play with your subsonic filter and see if you can gain any output. I would never trust what the dial says. Also, I believe that amp has an adjustable bass boost which might be giving you a ton of gain in the 40s making 30hz seem lower. Try cutting the bass boost all the way and playing with the subsonic. Try those things before doing anything big like building a new enclosure or buying a new sub.
One thing, when I first hooked my system up, the bass was real boomy like the sub was barking at ya (in a bad way). I've adjusted for this with the EQ on my P880prs and found that it is the 50Hz-band that needs to be turned way down below the other frequency bands for it to sound the best. I don't know why that is. It made me think that my box was possibly tuned much higher than I thought, but the bass hits real hard down into the 30s. And then it drops down to nothing.
