hardhitta47
I've got a 15" Rl-p d2 in a 3.1 cu. ft. (net) enclosure. It's tuned to 28 Hz. (but actually when I plug the port dimensions into WinISD it says 29-30 Hz.) I had the enclosure made for me to the specs recommended to me by Mike at SS. It's powered by a PG Xenon x600.1 producing 632 W @4 ohms.
My problem is this:
Although I love this sub and it hits really hard, I really want more low end. I'm not getting hardly any bass in the high-20s to mid-30s (Hz) frequencies. For example, on Young Jeezy "I Luv It", Project Pat "Cocaine", or on a lot of screwed & chopped tracks (RIP to DJ Screw), when the bass line hits the low notes my sub goes from loud as hell to almost nothing, like the sub is choking.
I really can't fit a much bigger box in my trunk. I can barely get the one I have through the trunk opening of my Civic. lol
What do you guys recommend?
So should I buy a bigger amp and give the Rl-p ~1kW?
OR
Should I consider a different driver. I can only afford to do one or the other, so if I switched drivers it would have to be one that will outperform a 15" Rl-p with 630W in a box no bigger than 3.5 cubes. Any advice would be much appreciated.
My problem is this:
OR
