how to get 16 8ohms speakers to =8ohms
wire two in series. Do this twice. Now wire the two pairs in parallel. Repeat that 3 more time to get 4 groups of 4 speakers. Wire two sets in series. Wire the other two sets in series. Wire your series groups in parallel. Final impedance is the same as the impedance of one speaker.
Holy crud...nice. Did you do this long hand? Can we see your work? LOL
Start by dividing the 16 drivers into 4 groups of 4 drivers. Wire 2 drivers in series and then parallel each of these pairs. Now each group of 4 is a 8 ohm load...
Now you have 4 8 ohm loads; do the same thing you did above and you'll get a single 8 ohm load.
just out of curiousity why in the hell would you want to end up with an 8 ohm load? last time I check most amps are 4 ohm mono stable or less so you would want to end up w/ a 4 ohm or maybe 2 ohm or even 1 ohm load but an 8 ohm, I'm a little confused what could this would do you besides what kind of subs are these if you want to wire 16 of them to 1 amp? don't tell me someone is playing with pyramid again... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Probably trying to get some sort of insane home audio setup. 8 to 16 ohm loads are pretty common with normal home amplifiers.
dude its for school, jus a lil project read his post
he himself doesnt want to do it, its jus generic 8ohm svc subs, so i doubt hell know the type
I'm going to have to guess the extra credit wasn't for wiring subs but something like 8 ohm resistors and he just said subs to make it applicable to car audio.
What kinda school do you go to where you get extra credit for wiring up bass?
I had to make out with my teachers for extra credit...
no the question is what school do you go to to make out with the teacher:toast:
Drive the biatch:driving:
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
429
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
292
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
424
djjdnap
FreakyFreaks ofall Freaks
djjdnap
indy-nap-lis
djjdnap
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
