How to draw a simple box in SketchUp
i have one question. ive been wondering since i have figured sketchup out yesterday....
how do you make the transparent pieces like that?
edit: lol cant believe i didnt see the above post
now for flaring the vent..
first you start off with the port the regular way.....
then you draw a square from the corner of the vent exit to the width that you want to make it , say you want a 3" flare, make the square 3"x3"
now draw a circle to from the edge of the square to the edge of the outside of the box.
next you start from the cender again but go to the inside edge.
now erase the edge of the square
erase the extra part of the circle.........
now you have a finished flared vent....
now you make a line on either of the ends.....and make the floor of the box solid again....
then pull it up and your good to go.
and if you want the lines to go away where the flare is, hold control and use the erase tool. it will leave the part there and erase the line.
As for adding color and textures go the the paint bucket, and go to carpets for carpet or colors for color. ( pretty self explanitory )
and if you dont want to have to color each piece the same color, courser to select the whole project and then paint it as one object
And if there are any other questions or tips that anyone would like added , speak up.
Hey, thanks for the how-to on drawing boxes... it really helped me out a lot.
Here's a question I have - When viewing the boxes in x-ray mode, I can see how the boards are placed together in the top of the box (red circles), but not in the bottom of the box (blue circles). Is there an easy way to do this or do I have to manually draw each small line in? I tried to draw each little line in once and it messed up some other things in the box //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Here's a couple pics... I borrowed one of yours, I hope you don't mind
you can just draw them in by hand.. in that view, it will go through the pannels to the spot you need.
I have a question... How do I make a face of the box angled? I have the top dimension and the bottom dimension I need, but I do not know how to make the front of it angle.
Thanks for any help
JBLCAMRY
KCB
JBLCAMRY
239, Florida
ALHII303
