How to design an amp rack
where you gonna put it? usually just build a plate with a raised cover. mount the amps and cut the holes. you could always start off with the first off-set, then just cut more holes as you expand. could even do cool comp. case fan, or fans in it so it draws air across the amps...
jchulski20
jchulski20
Jenison, Michigan, United States
akheathen
