Sold How to convert between all popular video formats (Windows/Mac)
Alex591
CA
You have a portable video player and would like to watch your favorite movies using it? Or you would like to upload your movie clips to YouTube, Google Video, Myspace and other online sites? Tipard Video Converter enables you to solve these problems quite easily with a few mouse clicks.
The following guide includes three parts show you how to use Tipard Video Converter.
Part One: How to convert between all popular video formats on Windows?
Things you will need: Tipard Video Converter
Make Preparations: Install and run Tipard Video Converter
Quick Start:
Step 1: Add files
Click “Add File” to add your video files.
Step 2: Set output video format
Click “Profile” button from the drop-down list to select the output video format such as AVI, MPG, MPEG and WMV. You can click the “Settings” button to set parameters of your output video such as Frame Rate, Bitrate to get the best video quality as you want.
Step 3: Click the “Start” button to start the conversion.
Part Two: How to convert between all popular video formats on Mac?
Thins you will need: Tipard Video Converter for Mac
Make Preparations: Install and run Tipard Video Converter for Mac (Intel Users, Power PC Users)
Quick Start:
Step 1: Add files
Part Three: Edit the video files (both for Windows and Mac Users)
1.Trim any segment
There are 3 ways that you can trim your video.
a.You can drag the button to set the start and end time
b.You can preview the video first and when you want to start trim click the left one of the pair button when you want to end click the right one.
c.You can set the exact start and end time on the left side of the trim window.
2.Crop any play region
There are 3 ways that you can crop your video.
a.We provide 7 modes on our “Crop Mode”
b.You can set your own mode on the left side of the crop window
c.You can drag frame to set your own crop mode
3.Snapshot and merge into one file
If you like the current image of the video you can use the “Snapshot” option. Just click the “Snapshot” button the image will be saved and you can click the “Open” button next to “Snapshot” button to open your picture.
If you want to make several files output as one you can choose “Merge into one file”.
Tipard DVD Ripper Pack is actually the combination of Tipard DVD Ripper and Tipard Video Converter. With the DVD rip software and video converter, you can convert DVD and any video to all the video and audio formats for all the portable players.
Input Formats: DVD, IFO folder and MPG, MPEG, MPEG2, VOB, MP4, M4V, RM, RMVB, WMV, ASF, TS, MKV, AVI, 3GP, FLV, MPV, MOD, TOD, MP3, MP2, AAC, AC3, WAV, MID, MIDI, WMA, M4A, RA, RAM ..
Output Formats: MP4, H.264, AVI, MP3, WMV, WMA, FLV, MKV, MPEG-1, MPEG-2, 3GP, 3GPP, VOB, DivX, Mov, RM, RMVB, M4A, AAC, WAV, OGG, RA.
Key Functions:
1. Set the video effects, audio track and subtitle
This pack allows you to adjust the brightness, contrast and saturation of video and volume of the audio by drag and click the adjustment bar. It also allows you to choose the audio track and subtitle to fit for your needs.
2. Cut any episodes from your DVD or video
Click “Trim” to capture any time-length video clips. You can set the “Start Time” and “End Time” to set the time of the clip or you can directly drag the slide bar to the accurate position.
3. Crop the video play region
By using the “Crop” function to crop off the black edges around video and adjust the video play region. It allows you to set the Crop Mode and Zoom Mode to exactly fit for your player.
4. Capture your favorite pictures and merge your wanted contents into one file
This Ripper Pack provides you to capture your favorite pictures when you preview DVD or video. You can join your DVD chapters or video pieces into one file for you to enjoy successively.
Alex591
Alex591
CA
mcsoul
