how to choose dry cell battery
yea... sorry to thread jack just trying to get more info on this as well before i purchase something I may not need. right now im aat 14.3 volts with just stock bat/alt and big 3 dont know whats my next move from here as far as the electric goes
I read this from somewhere before
"A good rule of thumb is 100 amps for every 1,000 watts"
terrible rule of thumb....thats just how much a typical amp pulls from you electrical....some amps more some amps less.....you have to remember AH plays the biggest role when looking for a battery....you first need to start with your alternator and figure out whats its idle amperage is and what its max amps are...then from there u can figure out how big of a battery you need....
isn't this what you are trying to power?
yes but upgrading the battery alone isnt going to solve anything...your alternator should be your first fix....with out it u will drag down ur battery over time
I don't agree that you should change your alternator first before you upgrade your battery or get a 2nd battery?
why not? if you exceed your alternator output more than just a little and more than occasionally, then all you are doing is dragging down the battery and overworking the alternator, which has to at least 3x the work to recharge the amount you drain. this is usually death to batteries and alternators. the alternator is where the power comes from, after-all...
ok thanks for all the replys to my battey situation well i still confuse so basically from what i read on replys so 1200 cranking amps for 1200 watt amp
biglion
biglion
nahsvlle tn
biglion
michigan born
    May 14, 2026
michigan born
    May 14, 2026
