How to bridge an amp?
To bridge an amp, usually 2 channel, but can also be done with a mono (sub amp) you have
+ - and + -
The two channel has 2 channels that allows you to use two speakers, but with bridging the amp you take the + from one side and the - from the other, bridging them.
Now with your sub the MTX 6000, what ohm is it rated? single four, dual 4, etc, etc?? You dont want the amp to go into protection or blow. Also what exact model of alpine do you have? Do you have a link?...
Originally posted by Woodmister ....can also be done with a mono (sub amp) you have
+ - and + -
That's incorrect. You cannot bridge a mono amp. There have to be 2 channels to bridge an amp. Mono amps have two sets of terminals simply to make it easier to hook up multiple voice coils. If you have a mono amp take a second and pull off the cover - you'll see that the 2 sets of terminals a parallel to each other just inside the amp.
c17globemaster3
c17globemaster3
Ocala,FL
Woodmister
