How to adjust idle speed?!?!
not possible without some kind of module/programmer. its computer controlled
if you adjust it it will idle higher until you turn the truck off.. then it will default that position and idle at stock rpm again.
you can only do it manually if its carbeurated like my beasty 76 and 73 k5 blazer. And you would use a flat head screwdriver not a wrench smarty pants. Gl adjusting that computerized sack of crap
Plus
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
825
Hi, I'm new here and the current car audio that I've had for a month is my first in my life, so I'm asking for your understanding 😉 I'm starting...
norrizzle90
Cant lose with 22's
norrizzle90
detroit, MI
DammitJames
