its a profile audio 400MSX mono amp, 600max @2ohms and 400max @4ohms. my sub is a mach5 MAW12, rms is 350watts. should i wire the sub for 2ohm, or 8ohm, the 2ohm load gives it double the power, if i wire it for 8ohms i should be able to turn all my gains up and produce a max of 400watts, 50 more than the rms of the sub which should be ok. alot better than 250 above the rms rating
