How my new BTL design look? Any problems
blackbonnie
The Revolution
its for two fully loaded 15" BTL's, going in an 06 silverado extended cab powered off two IA 20.1's. you guys see any problems. Fairly basic design, just looking for input.
Specs:
175 in^2 Port Area
31" Length of port
35 Hz
12.73 ft^3 Gross box volume
9 ft^3 Net box volume
3.14 Port Displacement (cubic feet)
0.6 Driver Displacement (cubic feet)
3.74 Total Displacement (cubic feet)
External: 19" x 25" x 55"
Internal: 17.5" 23.5" x 53.5"
Port: 17.5" x 9" x 31"
i went with 14 in^2 per cubic foot, what would you guys recommend? ive always went with 16 per cubic foot
Well on second thought it should probably work out ok. It's always easier to make a port plug than make a port larger. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah i will run a couple dowels for bracing and some 45's in the corners. how much displacement with a 45 in each corner usually run. but does everyone think that the port area is fine, or is it to big, or what. i went with 14 per cubic foot and most reccommend 12-16 so i figured id go halfway. any more opinions?
Are you supposed to figure the port area using net volume or gross volume?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Multiply the height of the opening of the port times with width of the port.
no he means how do you figure out what your port area needs to be. also how does my design look "idesignboxes" . do you see any problems with it, with the question directed more towards to much port area or do you think it will be fine? think i will have any port noise?
What software program outputs the rendering that was posted? It looks like a lot of you are using it.
No BOX program does that. You figure out the dimensions on paper or using one of the online calculators, you then plug those dimensions into a program called Sketchup. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And no, it's not as easy as typing in a few dimensions and *bam*...enclosure. Takes a little time.
Unless we're talking about pairing them with amps of those ratings I wouldn't call that honest, but probably consistent with what the vast...
  • Locked
Negative 1aespinoza . The spider landing is to big on the newer 12 spokes like you posted . I need the old school 12 spoke. Nobody here has...
409
754
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
blackbonnie
The Revolution
blackbonnie
Grand Rapids, MI
blackbonnie
    May 16, 2024
    May 16, 2024
