My question is this...if an amp is rated for say 100wx4 at 4ohms(RMS) at 14.4V, how do they set the gains on the amp when testing to get these power levels? Do they just crank the gain adjustment all the way up and test max rms power regardless of whether the signal is clipped or complete crap? Or do they use the test signal and adjust the gain to the highest level before clipping indicating the highest safe daily level it could be run at and test the power at that point? I havent been able to find a definitive answer on this. And this same concept would apply to amps for subs also. I am getting ready to start building an SQL oriented system and want the most clean power I can get but want to make sure that I properly balance and match up all of my components. Thanks
