How many watts would this put to each sub?
AKMX824
Ok, quick question
How many watts would a Rockfrod Fosgate Amp P500-2 Specs below:
Put to two Shallow Mount Rockford fosgate 12'' Dual Slims SPECS BELOW:
There in a under rear seat box.
SUB SPECS:
12"
Impedance 4-Ohm x 2
Power Handling 400 Watts RMS
800 Watts Max
Voice Coil Diameter 2.5" 4-Layer
(6.35 cm)
Motor Size 52 oz.
Speaker Connector Dual 10 AWG compression
SPL (1W/1M) 86 dB
Mounting Depth 3.625 in.
(9.21 cm)
AMP SPECS:
Rated Power
continuous power 125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Total Power
total sum of 'rated power' 500 Watts
Dynamic Power
powercube measurement (info) 229 Watts x 2 @ 4-Ohms 0° Res
371 Watts x 2 @ 2-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 71% @ 4-Ohm
66% @ 2-Ohm
Crossover Controls High-Pass (HP): 50Hz-500Hz 12dB/octave Butterworth
Low-Pass (LP): 50-500Hz 12dB/octave Butterworth
Tone Controls Punch EQ2 Bass: 0dB to +18dB @ 45Hz and/or
Punch EQ2 Treble: 0dB to +12dB @ 12kHz
Function depends upon LP/AP/HP switch position
Wire each sub at 2 ohms and run one on each channel. The amp is rated at 250x2@2 ohms so you will get at least that. Most Rockford Amps are underrated a bit so I would say if your voltage stays in the 13.8+ range each sub should get 275-350.
AKMX824
AKMX824
Palmer, AK
ultimate157
