How many watts should my amp be if...
depending on how u wire it and if u wanna push it to its full potential, alot of different amps can do the job, i'd recommend the jl 1000/1 when it comes out or a fosgate 1000.1 and wire ur subs down to 2 ohms.
well if you plan to use a 2 channel amp the 4 ohms will be fine
but if you are gonna use the jl 1000.1 or the rf 1000.1 those amps are usually 2ohm stable
therefore you will have to wire the two subs in parallel...which will give you a total resistance of 2ohms
there is a simple formula to work it out :
let R be the resistance (ohms) of the subs
R1 will be the resistance after u hook them up in parallel
1/R + 1/R + .... = 1/R1 (correct me if am wrong someone)
then to get the final value...you invert the answer...which will be in this case R1
get it ?
your case
1/4 + 1/4 = 1/2
which is 2 ohms !
With a sealed enclosure your subs will perform best with more power than they're rated for. If I were you I'd be shooting for something in the neighborhood of 500 watts/sub.
Needing that kind of power I think a class D sub amp would be your best bet. Just do some spec shopping. You need 1000-1200 watts rms at 2 ohms.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
scott4251
scott4251
Michigan
audiolife
    May 16, 2024
    May 16, 2024
